Driver side door lock barrel turning
lewisnewson
Post Wed Aug 05, 2020 9:19 am
Hello!
I'm a new owner of a brilliant 1991 E30. I have a few small problems that I need to address and the first being that the drivers door doesn't seem to lock. When I turn the key the lock barrel just spins instead of locking the door. I can lock the passenger side door absolutely fine and the boot is a little tricky to lock but central locking takes care of that with the passenger door locking.
Any advice on the route to fixing this would be great! I understand I may need a new lock barrel for that door?
Thank you!
Post Wed Aug 05, 2020 11:26 am
There's an 'over centre' swivelling bit on the back end of the lock barrel (part of the dead locking system) that is probably seized, worn or broken.
Take off the door card, peel back the membrane, and flip off the large C clip that holds the lock barrel in place with a screwdriver, take it out, and see what's going on.
Welcome to the zone, and post up some pics.
lewisnewson
Post Wed Aug 05, 2020 12:49 pm
Brianmoooore wrote: ↑
Hi Brian,
Thanks for the info! I'll take a look and see what the state of the barrel looks like when I take it out.
BenHar
Post Wed Aug 05, 2020 7:49 pm
Moz
Post Wed Aug 26, 2020 11:12 am
Recently had to fix the drivers door lock on mine and access is the biggest issue! That link BenHar put was the same one I followed. On my 4 door there are only 2 small holes where the lock is so you have to reach in from the bigger hole to refit. I had to remove the glass and regulator as my fat arm couldn't fit!
