Bonnet Release Cable
ChrisHC
E30Zone Contributor
Post Tue Aug 04, 2020 4:09 pm
Is it possible to adjust the bonnet release cable? On my car it seems to have stretched slightly and the catch now only operates right the end of its arc, causing a fear that with just a little more stretch it will stop working at all.
ChrisHC
E30Zone Contributor
Post Sat Aug 08, 2020 2:48 pm
No one else had this problem ever?
Post Sat Aug 08, 2020 8:36 pm
No adjustment for the inner cable, but the outer can be adjusted with a little ingenuity, such as bending the bracket it fits in to behind the handle, or inserting a little packing piece. This may be what has happened, and bending it back may fix the problem.
ChrisHC
E30Zone Contributor
Post Sat Aug 08, 2020 8:44 pm
Many thanks, Brian. I am more used to a simple clamp on the end of the inner cable!
Post Sat Aug 08, 2020 9:07 pm
You could probably make up a fully adjustable arrangement for the outer by fixing a brake adjuster from a bike to the bracket.
