Hi all,
I fitted front fogs to my preface over the weekend but only the passenger side unit works.
I have swapped fuse 29 & 30 over to make sure its not that, it didn't solve the problem and the bulbs are good in both units as I have tested them.
The only way I can get the drivers side fog light to work is to run a cable from the power from passenger side over to drivers side but would rather keep everything original and not do this.
One thing I noticed when doing this, there are two sockets on the passenger side, one for the front fog light and the other I'm not sure. On the drivers side I could only find one socket to connect into unless the second socket is hiding somewhere and I have the fog light connected into the wrong socket.
Help.......
If all else fails, I'll get an auto electrician out to have a look if anyone knows of one in the North \ West Yorkshire region
Fitted front fogs but only passenger side works
biffer
All the folowing is from memory,so may be wrong, but on my '87 car the foglamp connector wires are yellow/brown and the extra connector on passenger side is for headlamp wash/wipe and ,being a 3-pin,you couldn't connect your f/lamp to it anyway.
damers2000
all sorted, I ended up cleaning all plugs etc and that did the trick..... something as simple as that
