Hi I'm trying to change the rear wheels bearings and I've a problem. The bearings that I took out measure 75mm large, 34mm width and 42mm inner.
I check shops and they only have with 37mm width.........
Any help to find this kind of bearings with 34mm??
Thanks in advance
Camacho
E30 rear wheels bearing
boiliebasher
Hi and welcome to the forum.
Maybe find a different shop?! Online? Or get them directly from BMW?
paultv
You need to put your VIN into Real OEM and pick up a part number from there or input your vin into Autodoc to find the correct item.
Paul
Paul
camacho
Hi, I´ve already check but never saw 34mm widht....only 37mm
Anyone know any bearing 34mm on rear E30 wheel bearing?
If we go online only appears 37mm......
thanks
Camacho
thanks
Camacho
flybynite
There are 2 bearing sizes for the E30 but both are 37mm width
(outer x inner x width)
75 x 42 x 37 (large)
72 x 39 x 37 (small)
You are either measuring wrong or someone has put the wrong bearing in
camacho
Thanks pal. I measure correct way and the place in suspension arm measure 34 ( bottom to circlips)
I will try some photos to show it
