Any ******* tips on how the **** to get the ******* bracket at the ******* bulkhead off? The ******* piece of ****!
Removing Throttle Cable
mark_i
2 flat bladed screwdrivers, blade width at least 5mm to close both tabs at the same time
Royalratch
Contours
Its harder to get the replacement retainer in position to whack in--make sure you have an assistant to let you know its lined up in position as its impossible to see it under the battery tray on an M40. A job that is not as easy as it looks.
boiliebasher
It's not that bad just a bit fiddly. Make sure plastic clip is right way up through bulkhead
Wingzero
Well time for me to bring up this thread. My throttle cable snapped and I’m about to replace it. Do you pinch on the sides (or top and bottom) of the block in the firewall to remove it? I watched a video of a LHD one in which the user just hammers it out. But based on the comments above it seems like you press in the sides of the block using the two screwdrivers. Am I right? Thanks
Edit: nevermind - i smashed it out with a big punch and installed a new one
reggid
Theoretically you compress the two wings but normally I just bash with large screwdriver to break them it’s pretty awkward.
E30 325is with M20B31
