Electrics - not my speciality.
I have the original factory BMW alarm fitted, and am having an odd issue with my spare fob. When I insert a battery, the light is constant on, but dim. When I push the button, it lights up - but never turns off completely.
It wouldn't be massively surprising if 30 year old electrics are nearing end of life, are replacements available?
Cheers,
Gus
Key Fob Issue
JungleGus
haryj
Have you got the type of fob with a angle on one end? If so they are very hard to get hold of. I would say get yourself into contact with an electronics expert, someone who repairs instrument clusters, ecu's etc. Give AC tronics or BBA reman a call, or alternatively a Auto locksmith who actually does repairs and not just replacements.
It can't be that much of a difficult fix. Hope you get it sorted!
Hary..
Hary..
Currently Restoring My 1989 - 325i Convertible, With some incredible factory options! [/b]
No experience of this particular fob, so this is a generic answer!
The 'light' on these fobs is usually a very simple circuit, comprising the LED, the push switch, and the battery.
The push switch in fobs is usually a very common surface mount type - a few mm square, black centre button, with four legs.
These switches appear in all sorts of electronic equipment, and I know from experience that they occasionally become 'leaky'.
Surface mount components are horrible to work on without the correct equipment, but not impossible if you have a good fine tip soldering iron, fine gauge solder and good short range eyesight. I used to have all three, bad sadly, the third component is now badly lacking.
Open it up and have a go. Start by removing the switch, and see if that puts the LED out.
JungleGus
That sounds about right - will give it a go! Cheers both
