Digital clock and Radio
xavier
Post Sun Jun 14, 2020 4:40 am
The digital clock and CD player both stopped working at the same time. As they are on the same fuse, I thought it had blown. A new fuse did not solve the issue. Any suggestions before I start following wires?
Ukhozi
Post Sun Jun 14, 2020 12:22 pm
Nope, just follow the power from FROM THE FUSE. As it has two units fail on the same power line it is likely to be a junction or connector.
Everyone has the right to reach the level of their own incompetence.
Post Thu Jun 18, 2020 8:45 pm
If this is the red/green wire from fuse 21, then it follows a tortuous route, doubling back on itself from a multi way junction point, situated inside the wrapped loom, part way back the LH sill. If this joint is constantly damp from wet carpet, then it has been known to cause problems from corrosion.
xavier
Post Sat Jun 20, 2020 3:33 am
I’ll have another go today, but I think it might be time to call in the auto electrician
xavier
Post Sat Jun 20, 2020 3:34 am
Does the digital clock have it’s own internal fuse?
