reverse lights
shedrool83
Post Fri May 22, 2020 6:39 pm
Might be me begin an idiot but can anyone shed some light on this problem i'm having .
My reverse light aren't working when i select reverse .
I have disconnected the plug at the gear stick and tested the loom that goes to the switch on the gearbox for continuity which i have when reverse is selected .
I have bridged the other end of the plug and the reverse lights work .
When i plug the the two plugs back together i don't have reverse lights .
What am i missing :mad:
Post Fri May 22, 2020 6:54 pm
How did you check the switch for continuity?
shedrool83
Post Fri May 22, 2020 7:10 pm
Brianmoooore wrote: ↑
Multimeter set on buzzer
Post Fri May 22, 2020 7:30 pm
On my meter, the buzzer will sound at anything under about 60 ohms. The combined resistance of the two reverse lights is about 3 ohms, and considerably less when not lit.
If the resistance of the switch was 30 ohms, the lights would get about 1 volt.
BMW reverse light switches are not of a brilliant internal design. The fixed contacts sit flush in their plastic mount, and there's no wiping action as contact is made by the moving jumper bar.
shedrool83
Post Fri May 22, 2020 7:44 pm
I will check the ohms of the switch tomorrow and see what i am getting.
