320i Convertible small restoration
bmw335icoupe
Hi,
I'm having some work done to my Convertible for its 30th birthday.
More photos to follow soon.....
‘91 w124 Mercedes-Benz 300E
`13 F30 320D Saloon
`90 E30 320i Convertible
`91 E30 318i Convertible - sold
`06 E92 335i Coupe - sold
`13 F30 320D Saloon
What sort of work are you talking about ?
bmw335icoupe
It started with an oil leak...
I had a very bad oil leak from between engine and the gearbox, suspected worn crankshaft seal.
Because it is a big job I decided to take it to Jordan from the JCMotorsport in Alton to remove the engine and gearbox, replace the seal and everything else that needed ‘love’ . Car had over 150k on the clock and had engine as well as engine bay covered with oil and dirt
Some photos of what happened...
`13 F30 320D Saloon
`13 F30 320D Saloon
bmw335icoupe
So it my look like not much has happened , but....
New crankshaft seal
New clutch kit
Skimmed fly wheel, because it was damaged with worn clutch plate
New sump gasket
New water pump
New timing belt
New spark plugs
New exhaust shield
New exhaust stud
Second hand thermostat housing
New viscous
As well as new disks and pads front, new ball joints and bushes front.
Next step rust!
New crankshaft seal
New clutch kit
New sump gasket
New water pump
New timing belt
New spark plugs
New exhaust shield
New exhaust stud
New viscous
Next step rust!
bmw335icoupe
Wheel arches had a bit of bubbling so I purchased repair panels
I could not find any for pre facelift convertible so I purchased pre facelift for a coupe thinking they are same, but not...
`13 F30 320D Saloon
`13 F30 320D Saloon
bmw335icoupe
But Jordan said that he can made them fit, and he did.
But first rot removal...
`13 F30 320D Saloon
`13 F30 320D Saloon
bmw335icoupe
And done more
`13 F30 320D Saloon
`13 F30 320D Saloon
bmw335icoupe
Repair work..
`13 F30 320D Saloon
`13 F30 320D Saloon
bmw335icoupe
He made it look pretty!
`13 F30 320D Saloon
`13 F30 320D Saloon
Tzantushka
Nice recovery & use of the sheetmetal.
bmw335icoupe
`13 F30 320D Saloon
`13 F30 320D Saloon
bmw335icoupe
This is Jordan’s next project
1965 MG with Mazda mx5 engine and a supercharger!!
Very original I say
Very original I say
`13 F30 320D Saloon
`13 F30 320D Saloon
Sanchez
Nice work.
Along with heavily uprated brakes and suspension I hope!
Favourite pastime, back in the day, for the modded Mini brigade, was to try and lure these things (and the Spitfires) into following us into cornners at speeds we knew they weren't going to get around them without extreme drama.
bmw335icoupe
Bigger brakes wheels and stiffer suspension....
But still in a car with no abs, traction and very skinny body!
They are looking for 200+bhp
That’s more per tone than the current m3!!!
`13 F30 320D Saloon
`13 F30 320D Saloon
bmw335icoupe
5th gear stock diff...
`13 F30 320D Saloon
`13 F30 320D Saloon
bmw335icoupe
5th gear z3 diff...
`13 F30 320D Saloon
`13 F30 320D Saloon
Tzantushka
Great for cruising.
- how does the Z3 diff go with acceleration around town?
bmw335icoupe
It suits my needs.Tzantushka wrote: ↑Thu Jun 18, 2020 9:46 pmGreat for cruising.
The car has never been quick, now is obviously slower, but it’s still a pleasure to drive around town. Just need to stay in second gear a bit longer if needed.
On a motorway it’s great. Even in the fast lane car feels comfortable and is not reviewing like crazy.
In essence it feels like a 6th gear.
No regrets
`13 F30 320D Saloon
`13 F30 320D Saloon
