Oil temperature guage
tha881
Post Tue Apr 14, 2020 8:53 am
I know there has been a lot of threads about this in the past, but I'm looking for the quickest and easiest way to install an oil temp gauge. As I've done the oil cooler delete it would be great to know how hot the oil is getting when doing longer runs and when the revs are in the upper range for longer periods. I was wondering if the oil filter location is a good place to take a reading.
I'm looking at installing this gauge near the hazard light switch
https://www.ebay.fr/itm/153263705745
And then a sandwich adaptor for the oil filter like this
https://www.ebay.co.uk/itm/353025329701
I may look for a better quality sandwich plate as that one seems too cheap.
Would that all be as easy to install as it seems? And is the oil filter location a reliable place to take a reading?
steve_k
Post Tue Apr 14, 2020 9:09 am
if you want to fit an oil pressure gauge then the ideal place for the sensor is the same place as the stock sensor using a T piece,
i take it this is on an m20?
https://www.e30zone.net/e30wiki/index.p ... l_Pressure
thats for a vdo gauge but the process is near enough the same.
Post Tue Apr 14, 2020 9:25 am
Oil filter housing is the best place to take your reading from, I wouldn't worry about the block being cheap, it's a lump of aluminium with no moving parts, it just needs to have accurate dimensions. Id replace the O rings as china always supplies sh*te quality O rings!
steve_k
Post Tue Apr 14, 2020 9:38 am
my mistake i thought you said pressure gauge,
my mistake.
tha881
Post Tue Apr 14, 2020 12:29 pm
Well done lads :thumb:
Should be quite straightforward then, and what I like about that gauge is i dont have to worry about cutting up the interior
Post Tue Apr 14, 2020 2:25 pm
Same as this guy
