Arch Specs Clean up
BristolE30
Post Sat Feb 22, 2020 5:53 pm
Hey zone
I was just wondering what people would recommend for tidying up small specs of rust on wheel arches? Any good products to use after a quick sanding/dremel. I don’t have an air compressor or anything and it’s just touch up, mostly tiny stone chips.
I’ve heard hammerite?
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
Post Sun Feb 23, 2020 1:13 pm
I have used their rust converter and it`s spot on.
BristolE30
Post Sun Feb 23, 2020 7:13 pm
martauto wrote: ↑
Did you just dab a bit of it on the rust then be done with it? Or did you prep it all/sand down
BMW E30 316 ‘87
Bristol, UK
Post Mon Feb 24, 2020 11:28 pm
Most of the areas I just took the rust off and applied the stuff and it has not come back .
The battery tray had a load of surface rust but this soon dealt with it (left over night) What you put on top to achieve a finished area I dont know about.
