Hi
Another question regarding a m20b25 (told1990) swap into m20b20 1990 cab.
I’ve got a 325 air box. My rubber boot fits the new air box but not the throttle body.
I know there are quite a few variants of the boot and struggling to find the correct one.
Not sure how to proceed.
Any help greatly appreciated
Part number for correct rubber boot
BenHar
Is your idle control valve 'T' shaped or 'L' shaped?
Does the right hand side of the throttle body have two brake servo hose sized connections or just one?
linke30
Hi Brian
The icv is t shaped and I have one sevo pipe.
In that case, I think the hose you require is 13 71 1 726 325, but I'm not 100% certain. It will be usable though, even if you have to block one of the branches.
Just done a google search for a pic. of that part number, which confirms that it's correct. Also checked the other one it could have been, and can clearly see that version is for the two pipe servo.
linke30
Thank you so much!
Ordered one!
Ordered one!
