Hi Jon
Please can you provide prices for the following items shipped. Parts are for my BMW E30 with M40 engine. Reg: H255 NHK:
Gear stick/Gearbox Parts
Plastic Bushing - 25111220600
Plastic Washers x 4 - 25 11 1 220 439
Gearbox Input Shaft Seal - 23 11 1 228 314
Gearbox Output Shaft Seal - 23 12 1 205 342
Selector Seal - 23 12 8 677 736
Flywheel bearing - 11211709934
Rear Main Seal Gasket - 11 14 1 432 240 - Does this require replacement when changing the rear main seal?
Exhaust
Gasket - 18 30 1 728 208
Nuts x4 - 18 30 1 737 774
Stud bolts x4 - 11 62 1 708 999
Suspension
10mm Lower Spring Pad x2 - 33 53 1 136 387
Upper Spring Pad x2 - 33 53 1 128 610
E36 Lollipop Bushes x2 - 31129069035
Differential
Steel Bracket - 33 20 7 572 717
Torx Bolts x12 -33 20 7 572 716
Radiator and Engine Hoses
Top Left - 11 53 1 709 051
Bottom Right - 11 53 1 715 220
Back Bottom Return - 64 21 1 381 192
To Throttle Body - 11 53 1 717 590
From Throttle Body - 11 53 1 715 155
Back Top - 11 53 1 715 154
Back to Heater - 64 21 1 381 191
To ICV - 11 63 1 714 527
Fuel Hose 8x13m - 16121180409 - 2 meters please
Miscellaneous
Tool - 54127199322
Brown, Green, Blue Old Style Fusees - 61131370987, 61131372628, 61131372626 - 5 of each
Door Lock Repair Kit - 51219061344 - Possibly the correct part. Please confirm this will work for drivers side door.
Many thanks
Harry
Winter Maintenance Parts
TurtleDesignTech
Cotswoldbmw
Hello Harry
Prices are:
Plastic Bushing - 25111220600 £9.12
Plastic Washers x 4 - 25 11 1 220 439 £5.62
Gearbox Input Shaft Seal - 23 11 1 228 314 £37.09
Gearbox Output Shaft Seal - 23 12 1 205 342 £21.00
Selector Seal - 23 12 8 677 736 £14.54
Flywheel bearing - 11211709934 £17.21
Rear Main Seal Gasket - 11 14 1 432 240 - Does this require replacement when changing the rear main seal? £7.81 N, the seal can be replaced in situ
Exhaust
Gasket - 18 30 1 728 208 £14.93
Nuts x4 - 18 30 1 737 774 £0.86
Stud bolts x4 - 11 62 1 708 999 £10.76
Suspension
10mm Lower Spring Pad x2 - 33 53 1 136 387 £11.42
Upper Spring Pad x2 - 33 53 1 128 610 £23.74
E36 Lollipop Bushes x2 - 31129069035 £49.20
Differential
Steel Bracket - 33 20 7 572 717 £20.87
Torx Bolts x12 -33 20 7 572 716 £19.98
Top Left - 11 53 1 709 051 £28.27
Bottom Right - 11 53 1 715 220 £43.01
Back Bottom Return - 64 21 1 381 192 £42.49
To Throttle Body - 11 53 1 717 590 £19.93
From Throttle Body - 11 53 1 715 155 £9.91
Back Top - 11 53 1 715 154 £14.22
Back to Heater - 64 21 1 381 191 £28.15
To ICV - 11 63 1 714 527 £50.20
Fuel Hose 8x13m - 16121180409 - 2 meters please £54.36
Miscellaneous
Tool - 54127199322 £8.56
Brown, Green, Blue Old Style Fusees - 61131370987, 61131372628, 61131372626 - 5 of each £11.20
Door Lock Repair Kit - 51219061344 - Possibly the correct part. Please confirm this will work for drivers side door. £35.60 and the number is correct.
Prices above are for the qty required.
The above prices are valid for 7 days from today.
All prices quoted are for Genuine BMW / MINI Parts, include discount for enquiring online and VAT and postage.
YOUR CUSTOMER ORDER REFERENCE NUMBER IS - P10474
Payment Options:
For orders under £500.00 and if the delivery address is the same as the registered card address.
Call 01242 335365 with your card details and customer reference number or via Paypal / Bank Transfer (Details Below)
If you would like the delivery to a different address then we can only accept Payment via Paypal or Bank Transfer
For orders over £500.00 we will only accept either a bank transfer or payment by Paypal.
Paypal – partscheltenham@cotswoldgroup.com
Please send payment as a gift to friends and family with your customer reference and your delivery address in the notes section.
Bank Transfer – Sort Code 20-07-71 Account Number 40292230 with your customer reference in the notes section but please call or email us with your delivery address.
PLEASE PROVIDE US WITH YOUR VEHICLE REGISTRATION OR CHASSIS NUMBER TO SECURE YOUR 2 YEAR MANUFACTURERS WARRANTY
Many Thanks
Jon
Prices are:
Exhaust
Suspension
Differential
Miscellaneous
Payment Options:
Many Thanks
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
TurtleDesignTech
Hi Jon
Appreciate you finding all those prices for me. Please can I purchase the following:
Rear Main Seal Gasket - 11 14 1 432 240 - £7.81
Exhaust
Suspension
Differential
Miscellaneous
Door Lock Repair Kit - 51219061344 - £35.60
I make the total: £435.21. Payment sent through Paypal.
Please can you double check part number: Steel Bracket - 33 20 7 572 717. In the US these are available for $5-6 each.
Many thanks
Harry
Exhaust
Suspension
Differential
Miscellaneous
Many thanks
Harry
Cotswoldbmw
Hello Harry
Payment received and everything is on order, one small problem though the 220 hose is now out of stock with
no delivery date as to when new stock will arrive if ever.
What would you like to do?
The 717 drive shaft curved brackets cost £2.90 each, so if you need 6 the total is £20.87
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
01242 335365
TurtleDesignTech
Hi Jon
Ah I see. I was only after one 717 drive shaft bracket.
If possible, please can you refund me for the hose and ship me one bracket. Credit should be £43.01-2.90 = £40.11
Please notify me when/if the hose becomes available. (I have PM'ed you my email address and phone number).
Thank you very much
Harry
Thank you very much
Harry
Cotswoldbmw
Hello Harry
No problem, refund sent.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
01242 335365
