Power steering to manual
- Brianmoooore
Manual rack fits straight on, but needs the matching lower steering link from the rack pinion to the flexi joint in the steering column, but it's a bit of a retrograde step.
The extra pullet needed for a steering pump simply bolts to the front of the existing crank pulley.
- Brianmoooore
Unfortunately, the pulley is different, as is the pump and its mounting hardware.
It would be best to buy all the bits from one of our reputable traders, who should know enough to include all the its you need. Parts from a 2 litre are the same as the 2.5.
