Kerosene vs propane heaters
Off topic, non E30 chat.
rix313
Post Sat Oct 26, 2019 8:42 pm
I have a propane heater in my workshop and it strike me as being expensive and inefficient. Does any one have any experience/comparison to the diesel/kerosene heaters available out there?
flybynite
Post Sat Oct 26, 2019 9:38 pm
If you can run them on paraffin they are OK but it is getting harder to get in reasonable quantities. If you run them on diesel they can be a bit smokey, and they can leave a bit of an oily residue on everything. A real PITA if you are painting something. Run for ages on a tank though
Propane do burn cleaner but you go through propane quite quick.
In a big shed like yours I would probably look at getting an infra red heater. Heats you and the car not all the air in the shed :D
rix313
Post Sun Oct 27, 2019 7:55 am
Cheers for the reply! The thing is I noticed it was quite damp in there yesterday and after having the propane burner on it did (albeit I know temporarily) dry out so something pumping out fire is preferable. But I get what you’re saying, I’m more heating the roof space lol.
Post Sun Oct 27, 2019 10:01 am
I can run a propane heater directly from my car. Another advantage of LPG powered cars!
Running a kerosene heater on heating oil should be possible if kerosene/paraffin is proving difficult to obtain.
flybynite
Post Sun Oct 27, 2019 1:59 pm
You can but the low-sulphur stuff doesn't burn any better than diesel. If you get the better 28 second oil it has a really high sulphur content and gets your throat, still doesn't burn as well paraffin.
If you get proper paraffin (not someone flogging cheap heating oil from a big tank) they burn almost as clean as propane when running just you always get a bit of a smell on startup / shutdown.
Post Thu Oct 31, 2019 8:44 am
The only downside to propane is the exhaust gas contains water which makes your workshop damp, I have a similar problem and usually just run the heater for less time to reduce the damp. A burner with a flue vented outside would be ideal, waste oil heaters are ok but take ages to heat a reasonable area, nowhere near as quick as a space heater
Post Thu Oct 31, 2019 1:59 pm
Ordinary heating oil is 28 sec - I've just bought 4500 litres of the stuff!
The sulphur content was dramatically reduced by legislation a few years ago, resulting in the accelerated demise of the oil pumps in many heating boilers. The new pumps always came with a label saying they were suitable for use with the low sulphur oil.
Satan
Post Thu Jan 09, 2020 11:23 am
Mate only has a small heater hooked up but burns waste oil that is drip fed, may not be ecologically sound but at least its a way to dispose of the old oil from oil changes.
flybynite
Post Thu Jan 09, 2020 12:21 pm
Trouble is they have pretty much been banned by EU regs. You can't even get the Chinese import jobs now.
To do that now it is a DIY, or something old and second hand. Having been on site when a Salamander went nuclear as they had a tendency for I don't think I would try either old or DIY.
Satan
Post Thu Jan 09, 2020 7:56 pm
Tony has been using his for a few years without issues, he is stuck in his garage nice and warm rebuilding the engine of his Daimler Dart....
