Water leek in n/s footwell
yetta
Post Fri Sep 27, 2019 5:10 pm
I have a water leaking into the footwell mainly when I wash the car. It is coming in from the external air vent above the wiper motor, where does the water drain from in this compartment ? 1990 E30 2 door
BenHar
Post Fri Sep 27, 2019 7:33 pm
A couple of points.
You have posted this in the non E30 help section.
Which side is the leak?
Ben
yetta
Post Fri Sep 27, 2019 9:12 pm
Sorry still got in the wrong section. Itis the n/s
steve_k
Post Fri Sep 27, 2019 10:18 pm
if it's the N/S (passenger side) then check behind the glove box where the wiring harness comes through from the fuse box as the big rubber grommet could have given up or worse there's a patch of rust.
Post Sat Sep 28, 2019 7:30 pm
There's two threads going on the same subject, from the same person, so stopping this one.
