Shrick cam
964russ
Post Wed Sep 18, 2019 8:52 am
Does any one know the valve clearance for 288 schrick cam.
M20 b25.
paultv
Post Thu Sep 19, 2019 6:38 am
Same...10 thou or 0.25mm cold
Use double springs to protect your engine.
Paul :-)
964russ
Post Fri Sep 20, 2019 8:25 pm
Double springs?
Mine is on standard springs, they make a rattle noise???
paultv
Post Sun Sep 22, 2019 8:20 pm
Shrick recommend double springs as their cam has a faster steeper profile which can stress the standard springs resulting in a breakage.
They are also stronger so getting the valves shut in time at higher revs.
That's the theory anyway.
Paul :-)
reggid
Post Mon Sep 23, 2019 4:56 am
i know of people using stock (new) OE springs but its not something id skimp on. also are you using new rockers?
E30 325is with M20B31
964russ
Post Mon Sep 23, 2019 9:13 am
Original springs and rockers.
Them double springs arnt cheap!
flybynite
Post Mon Sep 23, 2019 10:19 am
reggid wrote: ↑
I'm curious about the rockers, What are people using? I have an old BMW rocker, a new Vaico and a new Febi that is generally recommended in front of me and the design does not seem as good as the old BMW stamped rocker that came out of it.
The Febi has the same reinforcement behind the nut-stop but has longer arms than the standard rocker.
964russ
Post Mon Sep 23, 2019 12:17 pm
I've had a read about thease rockers.
Lots of different opinions.
Looks like if valve clearance is set right and you dont continually run over 7k, standard rockers are fine and seem to be better quality than any copys.
As for springs, think I might have to get sum double springs.
Theres a few different options, ranging from £200 rte.de
£250 catcam holds
£350 schtick
964russ
Cant spell
reggid
Post Mon Sep 23, 2019 10:29 pm
People seem to use the HD rockers but the quality has been hit and miss but most likely with the earlier versions. the pads dont look like as good a quality. I'm using OE but shot peened and inspected sold by MM
