m20b23 conrod length
boiliebasher
Post Fri Aug 30, 2019 10:31 am
Hi all,
I'm planning on building a m20 stroker setup in the future and I was just starting to gather some info as to which route to take.
However, one thing I was unable to find is the con rod length which came with the M20b23
I've already looked on the forum wiki pages and it lists all of them except for the m20b23?
I'm assuming it is 130mm and they simply just changed the crank throw to give it the 0.3L difference from the m20b20 block as the bores are the same.
Any help would be much appreciated.
flybynite
Post Fri Aug 30, 2019 10:52 am
Yep 130mm con rod length in the B23, 80mm bore, different crank and pistons
boiliebasher
Post Fri Aug 30, 2019 11:39 am
[quote=flybynite post_id=2959881 time=1567158753 user_id=71708]
[/quote]
Great, many thanks for the fast response! :D
Ok well at least I know now! Cheers
