55l petrol tank to 63l
shedrool83
Post Mon Aug 19, 2019 11:00 am
Got a 4 pot shell with a knackered fuel tank and i have a good 63l tank sitting whats involved in getting the 63l in and working as it should?
Steve
Post Mon Aug 19, 2019 11:32 am
From the wiki -
The 63 litre tank has a much more sophisticated internal syphon system to transfer fuel from the left side to the right, which results in the levels in the two halves not being the same. For this reason, the 63 litre tank has a sensor in each half, connected in series, to give an average level for the fuel gauge. If fitting this larger tank to a standard car, it must be paired with the appropriate fuel gauge in the dash cluster and will also need a return fuel line fitted.
webmaster@e30zone.net
shedrool83
Post Mon Aug 19, 2019 6:52 pm
From the wiki -
Thanks Steve .
Its the wiring side of things that i was worried about as the 4 pots body loom wont have the other sensor wire.
Steve
Post Tue Aug 20, 2019 9:05 am
Brianmoooore wrote:The body loom for a car with a 63 litre tank is slightly different than that for one with a 55 litre tank, in that it has a branch for the LH level sensor, but this problem can be easily overcome by making up and running a loom across the top of the tank from the RH sensor to the left.
shedrool83
Post Tue Aug 20, 2019 7:15 pm
Perfect :clap:
Post Tue Aug 20, 2019 11:29 pm
:thumb:
rix313
Post Sat Mar 06, 2021 11:06 pm
I have a further question about this. I have acquired a 63L tank and feel it would be a good addition to my road car. No sensors sadly. naturally, I currently have the intank pump and level sensor assembly. I also have a spare level sensor with one outlet from an M10 car.
My question is can I use these two components plus the correct gauge to make the system work? Fit the M10 sensor to the left side and seal the outlet, then a fly loom over to the right side?
Post Sat Mar 06, 2021 11:12 pm
That should work OK. You'll still need the 63l gauge for the cluster, though.
rix313
Post Fri Mar 12, 2021 9:59 pm
The Wiki is, well very vague on this. "Fuel gauges can be identified by a label on the side of the gauge." Do you or anybody happen to know the relevant numbers to differentiate the two?
