How do I tell if a potentially bodged 325i M20B25 is a 5E or 5K?
It is in an '88 facelift shell and has 173 motronic box but the early 2 vacuum pipe throttle body.
Thoughts?
Sorry, finger trouble I meant to type 6E or 6K
Good thought but a compression test won't give you the compression ratio, The only difference was a change in the height of the squish band on the piston giving a lower compression ratio but helpfully the critical piston measurement is missing from the wiki, even if I did wait to take the piston out and measure it.Cloggy Saint wrote: ↑Sat Jul 06, 2019 11:41 pmAh, never heard it referred to as that before. Don't really know the answer but a compression test would be the obvious solution.
No can't be that, The 25 6K is the early high compression engine from a chromie, way before the cat cars here. The FL cars that had emissions kit had the later 25 6E engine I'm sure of it.
