How to remove this cap and replace seal?
HJ1981
Hey guys,
for a while i have been trying to pop this cap off. Everyone claims it is "pulls out", but i can not seem to do it.
I tried squashing some thin screwdrivers under the cap, but they are thin and will break if i use too much pressure. vice grips and plumbers pliers did not help.
Please excuse me but what is it ?
HJ1981
It is a cap that covers up the mounting for the gear driven distributor on earlier engines.
Part #24 in real OEM:
https://www.realoem.com/bmw/enUS/showpa ... Id=11_0117
aimlessrock
why are you removing it?
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
flybynite
Well on top of what you have already tried, some penetrating oil and time, some heat to the block and hit the cap with a pipe freeze spray, or take the sump off and try to get something behind it . All I can think of. As they are NLA you don't want to damage it too much
As above, why do you want it off?
steve_k
if you remove it you can use a 6mm socket on a drill to turn the oil pump gears to build up oil pressure if the sump as been off or the engine has been rebuilt.
i did it on my last year.
Gavt
As well as the heat and freeze method, although its push fit held with an o-ring, trying to twist and pull at the same time.
I used a pipe wrench with soft jaws to hold it. But engine was removed so much easier to get the leverage on it
HJ1981
because it is leaking engine oil from the seal around it.
I was considering heating it, but was not sure, same with penetrating oil. Will give both a shot, the pipe wrench is the only tool large enough to "grip" that cap but small enough due to space.
Gavt
I work in the aircraft industry. They have a rubber layer on the jaws originally designed to remove stiff electrical plugs (screw in style) without damaging the external casing of the plug. Not exactly a pipe wrench but same style you could put tape on for similar effect
HJ1981
Just picked up a couple of thin head yet sturdier screwdrivers, if they break it's fine they were cheap. Also picked up a beefy pipe wrench as well, hope one of them works.
HJ1981
That cap is really stuck on there, she would not budge.
I shall go to the hardware store tomorrow, look for some other tool that can help out, any other suggestion(s) would be appreciated.
HJ1981
I was considering that, but i really do not wish to have some sealant/silikon splattered around it.
After some hard work and massaging, it finally budged! this tool was a bit "beefier" than the regular pipe wrench, but it is finally off.
New o-ring in, everything cleaned. Just came back from a pretty agressive autobahn run, will check on it later when it cools down.
