Interior light problem
CALIC
Post Wed Mar 06, 2019 9:45 pm
Hi all,
This is my first question on here and am hoping some one can help.
My interior light wont switch on if i open the drivers door but it will do if the passenger door is opened.
I checked the pin switch on the pillar and even bypassed it and still the same issue?
Any input will be appreciated.
Post Thu Mar 07, 2019 10:26 am
First thing to establish is whether you have the optional switch off delay module for the light fitted.
What are the exact colours of the wires connected to the two front door pin switches?
ChrisHC
E30Zone Contributor
Post Thu Mar 07, 2019 12:24 pm
Also, the switch on the light itself has three positions, permanently on, permanently off, and switched from the door switch. Have you checked that the switch is in the correct position, does the light come on permanently when it should, and have you checked the unit, it is not a particularly robust item and easily broken?
CALIC
Post Thu Mar 07, 2019 7:05 pm
The wire colours are brown/blue mix and a brown wire. Is there 2 relays one for each door or are they both connected to one relay?
@ChrisHC as started in my question above, the light will turn on if the passenger door open, so they are set in the correct possiton and working.
Post Thu Mar 07, 2019 8:46 pm
Brown/blue is the wire to the switch that controls the relay that allows you open the windows with the engine off and a front door open.
The other wire is the one the controls the lights, but it is not plain brown, unless someone has been messing. It's colour should be brown/blue or brown/yellow.
There are no discrete relays involved with the operation of the interior lights.
CALIC
Post Fri Mar 08, 2019 7:21 pm
Yes, you are correct i was just being a bit blind there. Its not all brown as it has purple/blue. So where is this wire connected to?
Post Fri Mar 08, 2019 8:01 pm
If the wires to both switches are brown/purple and brown/blue, then you do not have a light delay module fitted. The wire to the driver's door switch would be brown/blue and brown/yellow if you had.
Unscrew and pull out the driver's door pin switch, disconnect the brown/purple and connect it to a good body earth or battery negative with a piece of wire. Do the interior lights come on?
Contours
Post Wed Mar 13, 2019 3:54 pm
Switches can corrode and I have used these---just have to transfer the rubber cover.
https://www.ebay.co.uk/itm/UNIVERSAL-CA ... 0738636835
Post Wed Mar 13, 2019 6:39 pm
Contours wrote: ↑
OE switches are stainless steel and don't corrode. A small sliver of black plastic can build up where the contact surfaces meet however, but can easily be removed with a craft knife.
OE switches are double pole. These are only single.
silent32
Post Sun Jan 16, 2022 4:07 pm
Was there ever a solution to this? I have the identical problem.
All three of my other doors trigger the interior lights in their door-activated position. The driver's door does nothing.
What it DOES do, is light the electric window switches when you open the driver's door.
The wires are brown/blue and brown/purple. Brown blue is sitting at 12v. Brown purple is at 5v (odd?) Grounding the brown purple does nothing. I've also swapped the 2-pin switch for a brand new identical one from BMW.
I don't have a wiring diagram for this circuit so I can't really figure out what's going on. Am I right in thinking the other door pins simply break a circuit when they are pushed in, and when the door opens, they make the circuit?
The driver's door is obviously different with the 2 connectors. When the door is shut, the pin pushes in and disconnects the two wires from each other. When the door opens the body of the switch connects the two wires together.
The electric window illumination is somehow still working. What do I do next? Help! :mad:
BenHar
Post Sun Jan 16, 2022 6:46 pm
The switch doesn't connect the two wires together. It connects both to ground.
Ben
Post Sun Jan 16, 2022 7:09 pm
Brianmoooore wrote: ↑
silent32
Post Sun Jan 16, 2022 7:17 pm
Thanks for the quick reply!
Ok so the two wires both ground when the door opens. Through the body of the switch itself, via the screw in the door metal?
So the 12v blue stripe and 5v purple voltages are correct?
silent32
Post Sun Jan 16, 2022 7:18 pm
It’s a brand new switch?
silent32
Post Sun Jan 16, 2022 8:01 pm
And surely if it activates the electric window switches it is working in some way. Any ideas what could have happened?
Post Sun Jan 16, 2022 8:05 pm
silent32
Post Sun Jan 16, 2022 8:28 pm
No. That’s what I tried already. Nothing happens at all. All I know is that with it installed in the door the window switches light when the door opens and nothing else happens.
With the switch pulled out of the door frame I have 12v on the brown blue wire and 5v on the brown purple wire.
The old switch acted this way and so does the new one. Any ideas?
fixedwheelnut
Post Sun Jan 16, 2022 11:05 pm
Not too worried about the interior light fault but I would just like to say I am glad to see you posting again Brian, you had us all worried there for a while :clap:
fixedwheelnut
Post Sun Jan 16, 2022 11:12 pm
silent32 wrote: ↑
I would check the circuit from the lamp holder down to the switch, the fact you have 12v on the brown/blue wire with it off indicates there is continuity but there could be a high resistance somewhere so when current starts flowing it gets held up. Prime suspect is usually the lamp unit itself.
silent32
Post Mon Jan 17, 2022 6:53 am
I will check that as well thanks. They are also brand new Hella interior lights and bulbs too.
So just to be clear, the switch should ground both the electric window relay and the door-triggered interior light circuit when the door opens? Nothing more complicated than that?
fixedwheelnut
Post Mon Jan 17, 2022 11:34 am
silent32 wrote: ↑
exactly, probably the simplest part on the car :D :D
silent32
Post Mon Jan 17, 2022 12:49 pm
Excellent, many thanks. Sorry if it’s a bit of a stupid question, I’ve just never had interior light problems in any car before!
I’ll do a continuity test and it should show up a resistance between the interior light itself and the brown/blue at the door switch. Presumably it runs pretty much direct from one to the other down a single wire?
Post Mon Jan 17, 2022 5:17 pm
The Master has returned :bow:
silent32
Post Tue Jan 18, 2022 2:57 pm
silent32 wrote: ↑
The results are in:
The body of the driver's door switch does ground when screwed in.
The brown/blue at the driver's side interior light is at 12v.
The brown/blue at the switch is also at 12v.
Resistance of 100 ohms between switch and light.
Can't remember much electrical theory. Assuming it's the same piece of wire running from the switch to the light, how do I get at it to find the dodgy bit? I'm used to wires that either break, or don't, not give 100 ohms of resistance? The terminals at both ends are good and solid. Any help, or further tests I can do appreciated.
fixedwheelnut
Post Tue Jan 18, 2022 5:05 pm
silent32 wrote: ↑
silent32 wrote: ↑
The results are in:
I take it you are measuring the resistance with the power off, the 12v will effect the ohm meter, pull the fuse for the interior lights and recheck it.
onthames
Post Tue Jan 18, 2022 5:10 pm
How are you doing brian!
silent32
Post Tue Jan 18, 2022 6:37 pm
Pulled fuse, now gives no continuity at all from switch to light and 12v at both brown/blue and brown/purple at the switch end. At the light end, nothing on the brown wire, weirdly 1.5v on the brown/purple.
Grounding the light works to illuminate it so at least that works. Now just a case of finding where the break is in the brown/purple wire. Previous owner had some work done on the sunroof, guessing the wire runs up the A-pillar, along the edge of the roof to the driver's side light? Any tips on how to get at it?
fixedwheelnut
Post Thu Jan 20, 2022 2:59 pm
OK lets start fresh I have added notes to the diagram with the door shut so door pin switch is open no contact, you have 12 volts via fuse 21 up to the interior light bulb, because the brown purple wire is not earthed you will still measure 12 volts up to the switch.
With the door open the brown purple wire is connected to earth and current will flow through the bulb, so you will measure 12 volts up to the bulb and 0 volts - 0.5 volts on the brown/ purple wire.
Critical points for open circuit are the three pin connecters C303 and C304 at the base of each 'A' pillar and the position of the interior light switch itself which can be
1/ On all the time
2/ Off
3/ On when the door opens
Switch open door shut position and interior light switch switched to on with door open. Light will be off
Switch closed door open and interior light switch switched to on with door open. Light will be on.
silent32
Post Thu Jan 20, 2022 3:48 pm
That's really helpful, thanks for taking the time to sketch it all out. I don't think I'd really properly understood that the power is at the lamp but the switching is at the door. Everything at the lamp end is tested and fine, except no continuity between the brown purple at the lamp and the same wire at the door switch.
So the most likely break is down at the bottom of the A-pillar, as I know the door switch is fully working and so is the lamp - both are new, but I have tested all their contacts also just in case. Guessing the brown purple wire has a connection to both lights, but is it somewhere in the roof (I have a sunroof) or at some other earth distribution point?
I'll start digging around down there, and probably tackle my brake light switch while I'm in the footwell area, as my brake lights seem to be constantly on as well.
silent32
Post Mon Jan 31, 2022 10:32 pm
Have done my digging while changing the front speakers and tidying up under the dash. Brown purple from door switch disappears off into the loom and is not connected in any way to the interior lights. Another brown purple is hanging there with a spade terminal and this also comes from the loom and connects to nothing. Grounding the light itself works fine. So all I need to do is run a bypass wire from the light to the switch. What’s the easiest route?
