Jump Starting
ChrisHC
- E30Zone Contributor
Arising from the topic of the blown ABS ECU, is there a safe way of jump starting another car from an E30, or correspondingly jump starting an E30 from another car?
Forgive my ignorance but why should there be a problem ?
Brian ???
Brian ???
ChrisHC
Voltage spikes frying electronics
paultv
It's suggested that even when fast charging a battery, it is advisable to remove a number of fuses to protect the computers in the car. Burning out the zener diode in the ABS relay is pretty common when jumping the car - maybe wise to remove the ABS relay, get the car running and replace the relay when the car is in "stand alone" mode.
Paul
Paul
PattheCat
As someone who has recently fried their ECU relay through a jump start, I would recommend removing the battery and connecting to a trickle charge overnight
ChrisHC
Surely a trickle charger is not going to cause a problem? It never has on mine. When fast charging or jump starting, disconnecting the battery leads should protect the electronics in the car, at the cost of having to reset the clock, admittedly.
I was wondering if there was anything even easier, many people for instance will tell you to have the engine running, does that do anything to avoid voltage spikes?
