no start
Tot
Post Fri Feb 15, 2019 11:04 am
js did a cylinder head gasket change,new thermostat and water pump,now the engine js cranks and doesn't fire up,i can hear the pump engaging and also checked the fuel sender line so fuel is there,also chkd for spark by jumping the plug and the ws some present,now where shud i b looking next,please any assistance wil b appreciated
tia
Post Fri Feb 15, 2019 1:38 pm
Plugs wet with fuel after cranking?
It would help if you told us what engine you did this work on.
Tot
Post Fri Feb 15, 2019 5:22 pm
my bad,its an M20b20 engine,the plugs show fuel yes after cranking
