Touring suspension question
keith2874
Post Wed Feb 06, 2019 9:51 pm
Hi there
I have a 1990 320ise touring which has suspension which is best described as utterly shagged.
I am looking at buying H&R 30mm lowering springs and some bilstein b4 dampers - do standard b4 dampers work with the lowering springs or do I need a shorter damper? If so, do bilstein do a shorter version of the B4? If so, I've been unable to find any online
Thanks for any advice
Keith
Post Thu Feb 07, 2019 12:58 pm
B4s will be fine with -30mm springs. Note that they come without the dust cover and the essential load spreading washer at the top of the mount. The washer is built into the dust covers of OE dampers, and the whole assembly will swap over to the B4s.
keith2874
Post Fri Feb 15, 2019 9:41 am
thanks for that - will get them oredered
K
