E36 Propshaft Flexi Disk - Bolt Direction
joeyb
Post Mon Jan 14, 2019 9:58 am
Hi guys,
For those of you fitting or running M52 with ZF box and E36 propshaft....did you go to the trouble of fitting 3 bolts in each direction when fitting the flexi disk between transmission and propshaft? In the end I pulled the output flange off the box as the bolts were too long to slot straight in. Just checking I've done the right thing?
joeyb
Post Thu Jan 31, 2019 1:14 pm
Anyone know before I go ahead and do three bolts each way?
joeyb
Post Mon Mar 04, 2019 11:14 am
In case anyone checks here with the same question...
I decided to go ahead and pull the output flange off so I could get three bolts in facing the right way. Whilst I was in there I replaced the gearbox output seal for good measure.
