Fog lights tourer 94
Joe94
Post Wed Nov 28, 2018 1:30 pm
Hello
does any body know if there any difference
In fog lamps to fit 94 tourer
As I looked on ebay at e30 fog lights says does not fit e30 tourer 94
Thanks joe
Also is worth getting those cheapo fog lights of ebay or best to find some original fog lights
Cloggy Saint
Post Wed Nov 28, 2018 5:24 pm
Any facelift fog lights will fit, they are not model specific, just age specific.
ChrisHC
E30Zone Contributor
Post Sat Dec 01, 2018 2:46 pm
As the wiki says:
Front Fogs
Bulb: H3 12V 55W
At the front, two types of foglight were fitted to the E30, and are therefore one of the easiest ways of determining the age of the car. E30s up to 1987 (pre-facelift) will have square foglights, while later vehicles have larger units with one rounded corner. The fogs have a specific plug which is part of the main loom, and the wire colours are grey and grey/blue.
The foglights are held in a plastic frame which screws into the front valance. The switch can be either two separate buttons for front and rear, or a combined "bar" switch that operates both at the same time. These switches are interchangeable.
If you want the improved look of front fog lights, learn more about retrofitting front fog lights.
Post Sun Dec 02, 2018 9:13 pm
If you try to buy bits for a '94 touring, you will tend to end up with E36 parts. The only parts I know of that are significantly different on a '94 touring , compared to an earlier one, are the central locking motors, which by then are part of the actual door catch.This is definitely not an improvement.
