Low idle- distributor cap
Rafael
Post Wed Nov 14, 2018 6:12 pm
Hey guys I wasn't sure what category to post this under but ive been trying to diagnose a low/stalling idle for a while now and so far I've replaced plugs, tested the leads, can't find any vacuum leaks, cleaned and tested the icv and tps. And it's still consistently at 500-600ish rpm and hesitates sometimes after a rev. Could this horribly worn dizzy cap cause a steady but low idle? I'm almost sure it is just wanted to check first tho
Thanks 😁
paultv
Post Fri Nov 16, 2018 7:14 am
Wow, that's in a horrible state, looks like there's a massive wear track in the posts making an excessive gap between the rotor and contact.
If you want great idle, no missing and fast pick up keep your distributor spotless, open up every two or three K to clean, it has a huge impact on performance and general driveability.
Buy a new one,
Paul :-)
Post Fri Nov 16, 2018 4:44 pm
That does look well past its sell by date !!
Welcome to the zone as well mate, enjoy
Rafael
Post Fri Nov 16, 2018 11:07 pm
thanks guys :) you should have seen the cam and the old oil that came out of it.... :cry: :cry: from the service history that i got with the car it looks like it hadn't had an oil change in ~80k... I'm slowly going through and replacing EVERYTHING hahaha
