88 325is cooling/temperature issue
Bill-h
Wed Aug 15, 2018 1:31 pm
Good day all.
Been fighting an issue on an E30 I have for quite some time now and I am stumped.
The car.
'88 325is Auto, 211k miles
Symptoms:
Car starts and runs well, When started and idling, it comes to temp (Needle in the middle/12 o'clock) and holds.
When driving, it comes to temp (Needle in the middle/12 o'clock) and holds.
Coming OFF the road, coming to a stop.
temperature climbs. If placed in neutral and rpm's brought above 2000 RPM, cools back down.
What I have done.
New water pump, new radiator, new fan clutch, new belts, new fan shroud, new fan blades, replaced head with a freshly reman'd one. and finally, new BMW thermostat.
Did all of this in stages, not all at once.
When I put the BMW thermostat in, I added water wetter.
NOW, when driving, the temp climbs to just under 3/4. Temp still climbs when I come to a stop.
So,, I made it WORSE!!!
WTF man.
Help???
Bill
paultv
Wed Aug 15, 2018 2:08 pm
What thermostat did you fit? I mean temperature wise??
Paul:-)
Bill-h
Wed Aug 15, 2018 2:11 pm
paultv wrote:What thermostat did you fit? I mean temperature wise??
Paul:-)
I did not specifically look at the thermostat to see if it was stamped, RealOEM claims it's an 80c one. the one I pulled out was stamped 80.
Wed Aug 15, 2018 2:32 pm
Have you checked the little brass nut behind the dash onto the temp gauge ?
It can work loose and even fall off giving in both cases a false reading.
Bill-h
Wed Aug 15, 2018 2:37 pm
martauto wrote:Have you checked the little brass nut behind the dash onto the temp gauge ?
I thought of that as the tach jumps around. I have a new set of gears in and will be rebuilding the instrument cluster this evening.
paultv
Wed Aug 15, 2018 3:06 pm
Yeah, it should be 80c, and a rise in running temp when you stop is pretty usual - at least my 325 M20 does it. ( no electric fan )
Paul :-)
arrisbmw
Wed Aug 15, 2018 4:50 pm
is the viscous fan working correctly , some of the cheap viscous units are crap.
when idling with a hot engine you should not be able to stop the fan with a rolled magazine.
and a piece of paper against the Front grill should hold there due to the suck from the fan.
does the temp drop if you put the blower on max heat ? heater inside
arrisbmw
Wed Aug 15, 2018 4:52 pm
could be a faulty coolant sender or wiring from it..
arrisbmw
Wed Aug 15, 2018 7:40 pm
Bill-h wrote:Good day all.
The car.
Symptoms:
What I have done.
WTF man.
Help???
Bill
i think i,d be tempted to put the old stat back in, even though a pain.
Bill-h
Wed Aug 15, 2018 7:45 pm
arrisbmw wrote:is the viscous fan working correctly , some of the cheap viscous units are crap.
Viscous fan is working correctly, can NOT bring it to a stop while hot.
Temp does not change with Heat on or off, Does not change with AC on or off, Does not change with it 70 or 95 deg outside.
arrisbmw wrote:could be a faulty coolant sender or wiring from it..
I have not checked the wiring.
arrisbmw wrote: i think i,d be tempted to put the old stat back in, even though a pain.
Sadly, the wife emptied the trash :|
Bill-h
Wed Aug 15, 2018 7:49 pm
paultv wrote:Yeah, it should be 80c, and a rise in running temp when you stop is pretty usual - at least my 325 M20 does it. ( no electric fan )
Paul :-)
In the ,, 15 or so E30's I have been involved with, I have never seen the temp climb up when coming to a stop and the engine still running.
Well, I did on the race car, but,,,,, Mods.
arrisbmw
Wed Aug 15, 2018 10:35 pm
take the stat out and see what happens.
iirc if its rich , i,e to much petrol to air causes the engine to run hot.
The ”aperfect”a fuel air mix is called a ”astoichiometric fuel ratio.”a This is 14.7:1 , this is what the computer is trying to maintain all the time. but if a sensor is tell the ecu wrong info then obviously the "stoichiometric" cant be right.
nick496
Thu Aug 16, 2018 9:34 am
Did you end up tightening that nut in the end?
I had a similar issue on my old 325i. Took it to the mechanics to run a pressure test (actually to bleed it properly), they put the temp gun on it, the temps were fine, so just tightened the nut on the back of the temp gauge. Worked a treat after that.
Bill-h
Thu Aug 16, 2018 12:28 pm
I rebuilt the cluster last evening (replaced odo gears, cleaned everything including the contact surfaces UNDER the nuts and tightened the nuts).
Then,, it was downpouring. Didn't get the cluster back in.
Plan on putting it back together tonight.
Bill-h
Thu Aug 16, 2018 12:31 pm
Thu Aug 16, 2018 1:59 pm
Is the electric fan working when air conditioning is turned on?
My E30 struggles to stay cool in heat/traffic with the air conditioning on but I have no viscous fan, an 80/88 switch in the rad will bring the elec fan on earlier which will help your situation.
The condenser rad will be having an effect on cooling as air needs to pass through this before it gets to the coolant rad, if its old and blocked up then get it replaced.
Also fitting a 'hot climate' or 'tropical' rad which is bigger in capacity will help
arrisbmw
Thu Aug 16, 2018 4:30 pm
i didn,t think they had electric fans unless retro fitted.
If your temp does not drop when you put heater on its not an issue with the rad. as you said its new .
When i had a old blocked rad and car overheated if i put the heater on full blast it would cool down , because the heater matrix is taking the heat from the sys helping the main rad.
what you need is an infra red thermometer , just point and it tells you the exact temps. you should be able to work out from this whats going on , your be able to tell when the thermostat opens ( top hose gets hotter ) and your see the bottom hose getting warmer as water passes thru , (but not as hot as the top hose as the water is being cooled by rad )
as your temp gauge could be wrong. and mis-leading you.
I understand the 6 pots are hard to bleed the cooling sys, maybe you still got air trapped.
Bill-h
Thu Aug 16, 2018 5:23 pm
DanThe wrote:Is the electric fan working when air conditioning is turned on?
The AC fan (Electric in front is the condenser) does run when the AC is on.
Verified again last night that the Viscous clutch IS locking up when hot.
Wondering if I have the correct fan blades??? It's damm quiet and there is @ 1" room between the end of the blades and the shroud.
Any idea where I could get a "tropical" radiator??
Also thinking of running an "E" water pump pulley, they are smaller. this would drive the pump/fan faster.
arrisbmw wrote:i didn,t think they had electric fans unless retro fitted.
Bleeding the system isn't that hard, if you do it right (Bleed screw on the top if the t-stat housing) . Confident that system is bled correctly.
Will "Borrow" the calibrated infrared thermometer from my analytical lab.
B
arrisbmw
Thu Aug 16, 2018 5:44 pm
good luck hope you get it sorted.
let us know how you get on. and what the issue is/was
ah
Thu Aug 16, 2018 7:04 pm
I hope I didn't do the wrong thing,my brass nut fell off and short term replaced it with an ordinary steel nut and never replaced it,have I done the wrong thing ?
Bill-h
Thu Aug 16, 2018 7:07 pm
I would think that as long as it holds tight, you'd be fine.
The nut pulls against plastic.
