Prices please!
Sensi
Hi, having trouble getting parts together to put my Touring through the MOT. Failed on headlamp adjuster, the hydraulic switch under the steering... anyway, the garage has asked for the following to secure the light clusters.
From realOEM :
09 - Adjusting screw : 8 off : 63121385397
10 - Intermediate piece : 4 off : 63121395252
11 - Joint sleeve (part has no quantity and is for use with adjusting headlamps) : 63121386616
would appreciate any help given!
Regards
Steve
From realOEM :
Regards
Steve
Satan
Remove the switch if not fitted doesn't have to be tested I believe.
Sensi
Yes, would have in hindsight, garage have tested it and failed it. Now it is listed as fitted equipment on the car and it must be repaired.
Cotswoldbmw
Hello Steve
Prices are:
63121385397 £13.35 each
63121395252 £7.81 each
63121378369 £2.91 each, the number you had ending 616 is for the auto adj you are taking out.
You may not need the qtys you had if you are only removing the auto adj set up
This price is valid for 7 days from today.
Your customer reference is #18778
Payment Options:
For orders under £500.00 and if the delivery address is the same as the registered card address.
Call 01242 335365 with your card details and customer reference.
For orders over £500.00 we will only accept either a bank transfer or payment by Paypal.
Paypal ”“ partscheltenham@cotswoldgroup.com
Please send payment as a gift to friends and family with your customer reference and your delivery address in the notes section.
or by
Bank Transfer ”“ Sort Code 20-07-71 Account Number 40292230 with your customer reference in the notes section but please call or email us with your delivery address.
Many Thanks
Jon
Prices are:
Payment Options:
or by
Many Thanks
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Sensi
Many thanks for your reply John.
I am actually replacing the adjuster unit and will require the 63121386616 parts, though I will have to check how many are required as the quantity was marked with an 'X' prefix on the Real OEM site.
Regards
Regards
Cotswoldbmw
The 616 are £5.14 each and you will require two.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Sensi
Thank you once again Jon!
Will order those parts in due course!
Would you be able to give me a price (& pt no:) for the adjuster unit itself? The garage seem to think that the one I supplied is incorrect as it's not long enough....
Would appreciate the help!
Regards
Regards
Cotswoldbmw
I would think it would be 63 12 1 394 251 but if you give me the reg or VIN I will double check
Jon
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Sensi
VIN: WBAAG62010EA60534
Cotswoldbmw
Hello
There used to be a difference if the car had ABS as the pipes routed differently but only the 251 part number is available and it now shows the 251 for both ABS and no ABS.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Sensi
Hi, the pt no I had from the supplier which was Hella 6NH003 395 - 211.
Can you give me a price on that assembly please?
Regards
Regards
Cotswoldbmw
The 251 would cost £177.42, there is no stock at all at BMW either in the UK or Germany.
I cannot cross reference the Hella part number I am afraid.
Jon
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Sensi
Is it something that can be back ordered. I'm really in a bind with this now!
Cotswoldbmw
In my honest opinion this will be months to get in as there isn't a delivery date and in my experience it is more likely to be made NLA no longer available than produced.
Jon
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Sensi
Okay Jon, thanks again for all your help!
I have sent an order for the 2 sleeves :63121386616 - coming in at £10.28 sent via Paypal.
Regards
Steve
Regards
Steve
Cotswoldbmw
Payment received and the clips are on order for you.
Regards
Jon
Regards
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Sensi
Hi Jon, still rumbling on with this damn headlight aim control nonsense... think the garage is fed up with it too and have decided to convert it to manual control! (great!)
However they have asked me to source the adjusting screws to make this work. It looks to me to be pt no : 63121385397 - 8 off
Please could you confirm this is what is needed and give me a price please?!
Thanks!
Thanks!
Cotswoldbmw
Are you replacing every adjuster of are you just replacing the ones that were previously headlamp aim?
Cotswold BMW Parts
01242 335365
01242 335365
Sensi
That's a good point, the garage gave me a slightly different pt. no. and said I would need 4 of the adjusters so I guess I only need 4?
I am just replacing the headlamp aim.
Cotswoldbmw
Thats weird because each outer headlamp has three fixing points only.
One if a fixed no adjustable pivot point.
One is an adjuster for left to right.
One is vertical adjustment (the automatic adjuster)
If you are just replacing the vert adj mech, you will only need one new adjuster per side.
These will cost £26.71 for the pair and we have them in stock.
Your customer reference is #21839
Payment Options:
or by
Many Thanks
Jon
Payment Options:
or by
Many Thanks
Jon
Cotswold BMW Parts
01242 335365
01242 335365
Sensi
Payment sent!
Thanks Jon
Thanks Jon
Cotswoldbmw
Can you PM mr your address details please as we have received the payment.
Jon
Jon
Cotswold BMW Parts
01242 335365
01242 335365
