Dash lights
MiniC
Wed Aug 01, 2018 8:34 pm
Hey zone
My 325i dash lights are constantly on 2 specifically. The handbrake light and the low brake fluid light stay constantly on when driving. I've checked the levels and all are fine any ideas?
mikemike
Wed Aug 01, 2018 10:02 pm
could be dry solder joints , have the same problem with the brake wear warning lamp on my dash board , will be sorting that out when I change my cracked dash board
Satan
Wed Aug 01, 2018 10:09 pm
The handbrake light might be the make or brake mechanism by the brake lever remove the cover you'll see it at the rear its pretty basic press the spring the cable pushes in.
Satan
Wed Aug 01, 2018 10:11 pm
Bake fluid could be the sensor disconnect it and short the contacts out.
Satan
Wed Aug 01, 2018 10:12 pm
Brake fluid could be the sensor disconnect it and short the contacts out.
