Speedometer and Odometer fault on 1988 e30 325i
Berto1
Post Mon Jul 09, 2018 9:09 am
Hi There,
I have a faulty Speedo and Odo. Changed batteries in SI Board, Sensor in Diff and Fuses. Speedo occasionally bursts into life and works intermittently for a few seconds and then stops - so I am guessing it is getting signal from somewhere. Checked gears in Odo and they look ok. Any help appreciated. Thanks. Albert
ChrisHC
E30Zone Contributor
Post Mon Jul 16, 2018 8:00 pm
Could be a loose connection or cable fault from the diff sensor. I may be shot down but I would try running a temporary wire from the sensor to as far as you can get up the original wire as you can get and see if that gets the speedo working.
aimlessrock
Post Tue Jul 17, 2018 9:35 am
likely a break in the cable from the diff sensor- as mentioned by Chris.
E30 320i Convertible (1989)
190 Mercedes (1988)
Berto1
Post Wed Jul 18, 2018 7:48 pm
Thanks Guys - will give it a shot!
gingerrusta
Post Fri Oct 05, 2018 8:05 pm
Berto1 wrote:Thanks Guys - will give it a shot!
How did you get on ?
