wishbone bush
mamodesen
Post Fri Mar 16, 2018 8:31 pm
can anyone tell me if the front wishbone bushes are different on different e30 models, as im getting mix info when i check compatibility on websites. i was under the impression that they're only different if its an e30 with air con
thanks in advance
(talking about E which fits in F)
Gavt
Post Fri Mar 16, 2018 9:47 pm
Nothing to do with air con. All e30s had the bush with the hole in the center (concentric) e30 m3s however had a off centred hole (eccentric) but the eccentric bush will fit all e30s and is a known upgrade. All 36s ones fit also.
Post Sat Mar 17, 2018 12:02 am
As well as being eccentric, the M3 bush doesn't have voids in it, so has a much greater lifespan than the standard item.
Parts 'C' in your pic. can usefully be replaced by year 2000 Ford Mondeo estate rear axle ARB links, which are a direct replacement, but feature ball joints at each end, again increasing long term reliability.
