I tried shorting the 2 pins on the connector, nothing.
Both bulbs are ok.
I checked Fuse 10, it's ok.
What else do I need to check?
Thanks, I will try that.Brianmoooore wrote:Pull the plug and socket at the base of the gear lever apart (under the gator).
Turn the ignition on and connect a 12 volt bulb between the green/white wire and a good body earth to check if power is present.
Connect 12 volts directly to the blue/white wire and see if the reverse lights light up.
This is true, but unfortunately it doesn't monitor the reverse lights, and the reverse light wiring doesn't pass through it.Connieblau wrote:There’s a plastic, black box called a lampenkontrollgerat (yes really) or better still a ”˜light lamp control modular relay’
1. 375. 909 which apparently organises the dash Lights out message for reversing lights etc. I have a rhd facelift convertible and mine is near-side just in front of where the wiring loom, antenna cable etc disappear into the boot. I did read somewhere they’re sometimes inside the boot. Black plastic box 100mm x 60mm x 30 deep with one white clip-in connector with 8 cables, one black connector with another 7. Nothing comes out the other side. Mine wasn’t kaput, but it wouldn’t be awkward to replace.
No the connector wasn't unplugged. I did think to at least check that before asking the forum.magpie wrote:i think he's un plugged the white block connector at the gear selector while removing the carpet .
You checked between the green/white wire at the plug near the base of the gear lever and earth, and there was no voltage with the ignition on, as I described in my first post?Ro3345 wrote: Switch works fine but not getting 12v to the connector.
Correct. Got 12v up at the fuse, but not getting anything at the green/white wire.Brianmoooore wrote:You checked between the green/white wire at the plug near the base of the gear lever and earth, and there was no voltage with the ignition on, as I described in my first post?Ro3345 wrote: Switch works fine but not getting 12v to the connector.
Brianmoooore wrote:DON'T TOUCH THE ALLEN BOLT! ...
