Hi all,
I'm changing my stock coil to MSD coil. Thinking to upgrade the stock HT lead at the same time but the stock HT lead got a pause lead. how did going to change the HT lead?
HT LEAD
There is no 'upgrade' over the stock HT lead is the short answer. What do you expect from a HT lead that the OEM item doesn't provide?
The only way you can transfer the pule sensor to a new lead is to buy a lead with a removable end.
