Zone Chip - live query ?
M3Tony
OK, running my Zone 'wild' chip, all seems OK, sharper response, etc...but tick-over is very high. When starting from cold, 1500-1800, then drops to 1000-1100 once 30 mins and hot. Very stable, unlike before, so happy with that, but is there anything I can easily do to drop it to 850ish, or is it OK running at 1000-1100 ?? Thanks, Tony
M5pilot
Your TPS might not be working. With engine off go to engine bay and open the throttle and you should hear a faint clicking noise - if not then you need a new one or you need to adjust the throttle.
