Drivers door eleccy window?
hammoj28
The other night my drivers side electric window stopped working. Think it did this a while ago but started working again. It still works if i open the door wide enough though and the passenger one works fine. I doubt it's a fuse as the passenger one works? Could it be a trapped wire somewhere from the body to the door? Thanks in advance.
24v tech2
demonbiker
check the door pin for the interior light ,clean the contacts and earth!
'90 M5 3.6 "Driven Hard......Put Away Wet!! "
hammoj28
O.k. will do this. Thanks.
24v tech2
