Fog light issue
Cloggy Saint
Just ordinary H3 halogen bulbs with one filament.
Turn the foglights on (so that you can see if the problem is 'accidentally' cured while working), remove the dim light (remove blanking plug halfway down the glass, undo the screw revealed, and pull the whole light out), remove the circular access cover over the bulb, turn the lights off, allow to cool, and check whether the 'glass' of the bulb is badly blackened.
If it is, then problem solved.
If not, then replace it, turn the lights back on, connect the black lead of a volt meter to a good body earth and measure the voltage on the metal base of the bulb and the centre wire.
One should read zero volts, and the other 12 volts +, but in your case one will be different.
If one wire measures 12 volts, and the other somewhere between 0 and 12 volts, then the light isn't being earthed properly. Check out the earthing terminal low down on the front LH inner wing.
If one wire measures 0 volts and the other somewhat less than 12 volts, then there is a poor connection between the fusebox and the light. Check the fuse pins for corrosion first of all, then the plug at the foglight.
Cloggy Saint
Satan
Are the lenses the same?
Cloggy Saint
I've taken tail light bulbs out of various BMW models that are so blackened that they no longer emit any visible light, although they are still 'working'.
If your fog light bulb was blackened, it was probably a result of it being held with bare fingers when fitted.
