e36 compact diff fit e30 ?
sweep
Post Wed Jan 31, 2018 8:37 am
As above -by swapping the output flanges will it fit a e30?
im unsure on the e30 prop fitting to the input flange?
Yeti
Post Thu Feb 01, 2018 12:27 pm
just swap the output flanges to e30 ones and it all should fit bud. its what im running on mine.
HRH-squidlips_III
Post Thu Feb 01, 2018 6:27 pm
got a z3 diff on temporaly till i sort out a lsd out, put e30 flanges on were to long so i cut them down 15mm
goes fine as a stop gap for now
sweep
Post Thu Feb 01, 2018 7:57 pm
So not a straight swap
Post Sat Feb 03, 2018 8:29 am
Yes ive fitted several
sweep
Post Sat Feb 03, 2018 9:08 am
Swap the output flanges and it will bolt up dan?
