Best way to flush engine oil after water contamination
Avinit4
Hello people, following hole in Head causing water to go straight into engine, can anyone recommend best way to do engine flush please? Thanks
Cheap supermarket oil for a few miles, repeat, fill with correct oil.
Avinit4
Would running engine on idle for 5 mins be enough, or do I need to drive it. Also am I correct to think you don't think I should add any type of flushing agent as well?
Avinit4
Is it Any spec for cheap oil or should it be 10/30 or something else? Thanks btw
Pretty much any multigrade will do. Best to change the filter when you put your good oil in.
Avinit4
Because engine very contaminated with sludge I'm going to use cheap oil and flushing agent.. And yes will also change filter with final oil
