Aerial wiring mess
Nickerz
Anyone know what wiring should be in place for aerial. I have a mess of spliced wires some potentially for a amp or signal wire that was in the boot. Looking to cut out what's not needed.
A parallel twin cable, consisting of one red wire and one white wire, plus the coax. cable from the antenna, should be fitted along the LH sill.
Red wire is power for the antenna motor, and white is the control signal.
