helicoil sub frame bolt hole.
steve_k
Post Thu May 18, 2017 9:49 pm
evening folks,
sorry the title ain't very clear :o:
got a bit of a problem, earlier tonite at a mate's i was helping him remove the front subframe on his e30, all going fine till the rear bolt (pas side) decided to snap of & leave about 15mm of it in the chassis rail.
managed ro get the remains out thanks to an "easy out" type drill bit (he did that while i made the tea)
now my question is this, would it be possible to use a helicoil to repair it??
if so what size would i need??
help me out please folks as he needs the car ready for mot on Tuesday.
thanks in advance.
steve_k
Post Fri May 19, 2017 8:32 am
anybody??
steve_k
Post Fri May 19, 2017 9:32 am
just got my hands on helicoil kit,
so let the fun begin (when it finally stops raining)
never used one before, i was thinking of using some thread-locker (red, permanent) on the outside of the insert & but none on the bolt when it goes back in.
yay or nay??
steve_k
Post Fri May 19, 2017 9:55 am
just a thought, would it be easier to retap/recut the bolt hole to a larger size? got a full tap & die set,
just trying to find out which will be easier/stronger.
Post Fri May 19, 2017 10:10 am
????? If you removed the remains using an 'easy out', then what needs repairing??
steve_k
Post Fri May 19, 2017 10:23 am
Brianmoooore wrote:????? If you removed the remains using an 'easy out', then what needs repairing??
sorry for not being very clear,
got the remains out, tried another bolt (same size) & it would seem the treads ar shot as the bolt just spins & wont "bite" thats why i thought about a helicoil.
jimf
Post Fri May 19, 2017 12:35 pm
You are going to have to tap out to a larger size for the helicoil anyway so if you can fit a bolt that is one size up you may as well just go for that.
steve_k
Post Fri May 19, 2017 12:57 pm
jimf wrote:You are going to have to tap out to a larger size for the helicoil anyway so if you can fit a bolt that is one size up you may as well just go for that.
Cheers Jim :thumb:
Looks like that could be the plan of attack then.
Post Fri May 19, 2017 3:21 pm
No need to use any locktight or such as the helicoil will hold in place really well.
steve_k
Post Fri May 19, 2017 3:22 pm
martauto wrote:No need to use any locktight or such as the helicoil will hold in place really well.
Thanks for that mart :thumb:
Post Fri May 19, 2017 5:13 pm
By the way, is this a blind hole or through hole?
steve_k
Post Fri May 19, 2017 5:20 pm
It's a blind hole,
Rear mount hole on the front subframe where it bolts to the chassis rail.
steve_k
Post Sat May 20, 2017 9:15 am
well i got the helicoil fitted yesterday,
was surprisingly easy to do, don't know what i was worrying about lol,
put the "new" bolt in, tightened it up to spec & all seems well,
fingers crossed for his mot next week,
as for the helicoil kit, not bad for under a tenner, might look into getting a few bigger ones just in case.
Post Sat May 20, 2017 1:15 pm
I`ve used these for years on soft materials which need a strong thread and never had any issues with them at all.
It`s no dark art is it lol.
steve_k
Post Sat May 20, 2017 1:19 pm
martauto wrote:I`ve used these for years on soft materials which need a strong thread and never had any issues with them at all.
thanks for that mart, was just a bit unsure as i've never done it before, was afraid i'd screw it up :o:
but, nice & easy, only took about 20mins taking my time.
worrying about nothing lol.
maxfield
Post Sat May 20, 2017 4:20 pm
Where did you get a helicoil kit for under a tenner?
steve_k
Post Sat May 20, 2017 4:29 pm
maxfield wrote:Where did you get a helicoil kit for under a tenner?
Off a mate of mine, had it on his shed & decided to let it go as he wasn't using it anymore.
Plenty on eBay cheap enough.
maxfield
Post Sat May 20, 2017 7:33 pm
I've got about 10 helicoil kits and all have been about £30-£40
steve_k
Post Sat May 20, 2017 7:43 pm
seen plenty starting at £20 from the likes of machine mart & even your place.
seems to depend on what size thread you want.
