My new engine
Simon
Post Wed Jan 25, 2006 5:04 pm
Gave the replacement engine that Glenn very kindly fitted for me a good service yesterday, it had a slight misfire, so wanted to get it sorted.
Changed oil, filter, coolant, plugs, dizzy, rotor arm, timing belt, tensioner, water pump, viscous, rocker gasket, 2 temp sensors and the thermostat.
Got to say, looks like the engine has been a little neglected, oil was black, viscous was date stamped 1988, rotor arm was starting to disintegrate, and was also stamped 1988, dizzy looked worse for wear, was stamped 1994, plugs looked like they'd been fitted since 1901, and the timing belt was very loose 8O !
In all, glad I did it when I did, and the car drives 100% now!
Feels like I've gone from a 2.0 to a 2.3 and now it feels like a 2.5 should!
nav786
Post Wed Jan 25, 2006 6:02 pm
good job, u lucky git. gotta get mine done :cry:
FOR SALE
SONY PSP'S £100
Simon
Post Wed Jan 25, 2006 7:15 pm
Get it done, in all it took me about 4 hours, and Ԛ£160 from GSF.
glenn
Engine Transplant Services
Post Wed Jan 25, 2006 7:23 pm
glad you got it sorted si,
did you get my text on monday?,
got home a little late monday to return the call
Simon
Post Wed Jan 25, 2006 8:00 pm
glenn wrote:glad you got it sorted si,
Yes mate, I did, it wasn't that cold after on Monday night so no worries there, I went out for a spin in it though at about midnight just to make sure!
eun
Post Thu Jan 26, 2006 3:11 am
si that was money well spent.
after that shopping list i would have expected a lot more
than that. 8O :wink:
M3Tony
Post Thu Jan 26, 2006 8:12 am
Simon - you mentioned a great list of service parts for the 325i, and for Ԛ£160....is that a 'special pack' you can order from there, or order them individually ??
Simon
Post Thu Jan 26, 2006 10:14 am
All of the above was ordered from GSF, and included delivery, the only thing on the list which I didn't buy from GSF was oil and the viscous as I had one here already, so add Ԛ£30 if you want a new viscous.
There is no service pack BTW, I just bought them all seperate.
M3Tony
Post Thu Jan 26, 2006 11:44 am
Cheers Simon - I'm moving on....try to do service parts myself ! Regards, Tony
