Is it possible?
Cloggy Saint
Post Tue Feb 21, 2017 2:51 pm
Could a variable speed intermittent wiper system be installed in an E30? I know they're fitted to later models and wondered if it could be done.
Post Tue Feb 21, 2017 3:01 pm
Of course, anything is possible... I fitted a Linwood Electronics one to my 1970 Morris Traveller a few years back and it's still working nicely. :)
Velleman sell a kit, via Maplin, for example:
http://www.maplin.co.uk/p/velleman-wipe ... -kit-ve03d
Or this one from Quaser:
https://www.quasarelectronics.co.uk/Ite ... controller
Cloggy Saint
Post Tue Feb 21, 2017 3:27 pm
Cheers! Easy and fun to solder? I've never found soldering to be easy or fun :) . Do you get a nice, subtle switch to control the speed? I guess it would be completely separate from the original stalk.
Post Tue Feb 21, 2017 3:47 pm
My Minor's one just has a discrete potentiometer (rheostat) control fitted to a little bracket below the dashboard; the rotating pot incorporates an on/off switch, similar to many basic radio receivers - rotate to switch on, then adjust to set the delay period, which ranges from a couple of seconds to almost 30 seconds or so - very useful in fine drizzle.
Post Tue Feb 21, 2017 10:22 pm
I had a home made one in my Mini in 1970, which had no visible controls. To program it, you simply operated the single wipe, then operated it again when the screen was sufficiently obscured to warrant it. After that, the wiper would operate again repeatedly, after the same interval. To stop the wiping, you flicked the single wipe once again, and then again if you wanted to set a new interval.
TriggerFish
Post Wed Feb 22, 2017 8:54 am
That above solution is exactly how the older VWs (Golf 2 era, at least) used to work. Nice idea I think. I retrofitted the relay into a later model Polo and it worked. I wonder (but highly doubt!) if the pin outs match an E30 wiper relay...
Edit - no - totally diff pins/connections :(
