New Wheels
fastdave
Fri Nov 25, 2016 9:16 am
After some new wheels for rallycar can get some made pcd 4x100 centre bore 57.1 but can only do a et of 35mm in 7x15 wheel will this be ok ?
Theo
Fri Nov 25, 2016 9:30 am
yes but you'd probably want to use a 12 or 15mm hubcentric spacer otherwise you will be reducing the track width and also likely to have clearance issues to brakes and also the upright.
fastdave
Fri Nov 25, 2016 11:28 am
What would be the ideal et ?
Theo
Fri Nov 25, 2016 2:18 pm
Well standard 15x7 BBS are et24. You could easily run et35 with 15mm spacers without have issues with tyre to wheel arch clearance.
fastdave
Wed Nov 30, 2016 1:09 pm
Went for ET 23 in the end same as some of my old wheels :D
Theo
Wed Nov 30, 2016 1:17 pm
Nice, what wheels are they?
fastdave
Thu Dec 01, 2016 1:26 pm
Team Dynamics Pro Rally 7x15 gunmetal with steel inserts
rix313
Mon Dec 05, 2016 7:17 pm
I run the 1.2s ET15 but they probably aren't up to rally abuse.
fastdave
Mon Dec 05, 2016 11:20 pm
I have been running std sport alloys but have lost count of bent ones I have . Manx tarmac roads are hard on wheels !
