another mirror issue
ravstar13
Post Wed Nov 16, 2016 2:41 pm
For a few weeks my mirrors have had issues when adjusting, they kept clicking and then never doing what I want it to. They seem weak, as they are always moving when driving(with wind or bumps). Now I cannot hear any noise and are not moving a single bit. Whats the best way to refresh them, what would i need to get or repair them.
TriggerFish
Post Wed Nov 16, 2016 4:54 pm
When mine did the first stage (jumping around, weak, not moving) it was simply that the ball and socket joint on the motor had popped out.
Very easy to see, and fix, once the glass was removed.
If the motor's not working, that sounds like another problem.
ravstar13
Post Wed Nov 16, 2016 5:00 pm
Where is the motor actually located if i may ask?
brutus
Post Wed Nov 16, 2016 5:44 pm
behind the mirror glass, , there is a hole underneath the casing, carefully push a rod up & turn to remove glass,
MANY e30 PARTS FOR SALE.
( all models available )
318i baur 1986 auto.
ravstar13
Post Wed Nov 16, 2016 5:51 pm
ah cheers guys, will have alook ,,can you still get motors? im guessing all second hand ones must be knackered by now? and are they straightforward to replace? Thanks guys
Post Wed Nov 16, 2016 7:05 pm
Most second hand motors will still be as fresh as the day they were made! They are unlikely to have run for more than a total of a few minutes in their entire life.
Note that the same motor is used to move the mirror sideways is also used to move it up and down. What looks like a second motor is a solenoid that changes the motor drive from one to the other.
If your mirror moves over bumps, etc., the clips that hold the plastic rack against the drive pinion have probably broken, allowing the teeth to slip, and whereas, I have bodged this together in the distant past, when E30s weren't being scrapped, there shouldn't be any problem getting a second hand one these days.
As said above, if all is silent now, you almost certainly now have a second fault, and the first thing to do is prise out the mirror switch, unplug it, and connect a 21W 12 volt bulb across the brown and green/white wires to check that power is reaching the switch with the ignition on.
ravstar13
Post Wed Nov 16, 2016 7:52 pm
Thank you Brian, I will attempt over the weekend, if weather is all ok and see what I fine. Cheers pal
