Spit roast and GAPE
ross_jsy
Post Sun Nov 06, 2016 5:29 pm
So for the past few weeks I have been helping my friend repair the rust on his touring and thought you guys would like to see as he isn't a zoner.
Car on a spit:
Spits are a god send!
Rust caused by a poorly installed car phone in the rear arch (partly cut out):
Cut back to fresh metal
Plate welded in:
Surface dressed:
Hole at base of rear arch cut out to fresh metal:
Plate made and tacked in place:
Surface prepped:
Back of the cill, inner arch and part of the outer arch were rotten. While prepping and cutting out I found filler. Appears to have been caused from a previous accident repair:
Those are probably not even a quarter of the repairs I've done. What has shocked me is on the surface this was a clean shell and it has taken 2 of us 4 weekends of 2 12+ hour stints in a fully equipped bodyshop and we aren't even half way to painting it. I dread to think how much work a half bad shell would actually require, and what the bill would be.
I taught myself to weld so any tips are greatly appreciated.
Ross
maxfield
Post Sun Nov 06, 2016 5:44 pm
When it comes to rotten shells you can put a time on it. I spent 324 hours welding a Mini shell up. The repairs look half decent. When you're welding are you trying to do a continuous bead? Or spotting? Also what gas?
ross_jsy
Post Sun Nov 06, 2016 5:55 pm
In my misspent youth I once helped repair a very rotten mini. Lets just say we didn't weld anything and you could date the repairs from the newspaper we used :D I still see it driving around 7 years later 8O
I tend to spot most of the time as even on the lowest setting the welder loves to blow holes. Where the metal is thick enough I'll lay a continuous bead. Some of the repairs were done with a temperamental older welder. Since switching to a new snap on one it has been far easier to lay weld with. Off the top of my head its argon/CO2 mix
maxfield
Post Sun Nov 06, 2016 6:06 pm
A good welder always helps, some people say they can weld with any old welder, but that's bollocks. I always spot on thin stuff. My old welder I always had low wire speed and slightly higher heat and it worked really well. Now I've bought a new welder I'm still working out how to get it right.
I asked about the gas, I was using pure CO2 and it looked ok but not the best, went on to an argon/CO2 and it made a world of difference.
TPS
Post Sun Nov 06, 2016 7:35 pm
Nice One
Sanchez
Post Sun Nov 06, 2016 9:27 pm
My tourings needing some of the same repairs soon.
Post Sun Nov 06, 2016 10:15 pm
I see it's moved then. :mad: :D
Gert_8
Post Sun Nov 06, 2016 10:25 pm
Coont. And you know why! :-x
Post Sun Nov 06, 2016 11:02 pm
Gert_8 wrote:Coont. And you know why! :-x
Hahahahahah :mad: :cool:
ross_jsy
Post Sun Nov 06, 2016 11:05 pm
Gert you didn't have time to weld with all the romancing you were doing with Gary :D
Post Sun Nov 06, 2016 11:15 pm
HAHAHAHAHAHA. busted!!!!
Gert_8
Post Sun Nov 06, 2016 11:23 pm
You should have seen my continuous beads :D
How is little Gary?
ross_jsy
Post Sun Nov 06, 2016 11:45 pm
He has had the shits all day, you really bunged the poor bastard up!
Post Mon Nov 07, 2016 12:08 am
I'm surprised he has problems holding anything in, after a night with Gert :mad:
ross_jsy
Post Mon Nov 07, 2016 7:48 am
That says more about Gert's size* than anything else.
*watch him blame the cold hot tub :)
Post Mon Nov 07, 2016 9:13 am
Hahahaha :mad:
