Bc racing coilovers
Tomo_e30
Fri Oct 21, 2016 8:53 pm
Doesn't anyone have any knowledge on these coilovers, looking at purchasing a set for my 1990 316 but unsure of strut size? 45mm and 51mm?
Can't anyone advise?
Tom
wullie325i
CAUTION - unreliable trader!
Fri Oct 21, 2016 9:33 pm
i think they come with bigger struts regardless of model.
Tomo_e30
Fri Oct 21, 2016 9:36 pm
wullie325i wrote:i think they come with bigger struts regardless of model.
I did wonder because when you read the discription is says they come with larger struts but it gives you a drop down to select either a 45mm or a 51mm slightly confused .
As for spring rates I was thinking of going for 8/6 kg/mm
wullie325i
Fri Oct 21, 2016 9:37 pm
you can fit either size without issue so if theres is a choice go with 51mm imo
