'89 320i been sat for about 2 years. Able to start before with no issues. Now when I go to start I get lights on dash but when turning key to crank nothing......
Gone through the Wiki page for starting problems.
New battery , coil tested ok , DME relay comes on , fuel pump relay doesn't unless I bridge the connections so guess thats a fault. Tested green cable and black/yellow cable and can find no breaks. Getting voltage at the ECU & starter motor. Unable to start from diags plug though?
fresh oil , coolant and fuel.
Help help please
