Best rear tyre size on a 9j rim? 60mm Lowered convertible
e30-unit-soldier
Post Tue Sep 20, 2016 4:03 pm
I got some staggered wheels for my cab the rear tyres will rub most definitely as the car is lowered just wanted to know what tyre size would be good for the rear?
Also are "stretched" tyres very safe?
7 1/2 j front
9 j rear
D reg 325i cab 60mm lowered
bobbin1982
Post Tue Sep 20, 2016 8:07 pm
I have heard stories of stretched tyres coming off the rim quite a lot!
I wouldnt lets put it that way :eek:
Driving my digger!!!!
Scotty200
Post Tue Sep 20, 2016 9:01 pm
A good guide is to use the website willtheyfit.com you put your existing wheel set up rim size,et, rim width and tyre sizes then put in your new wheel set up and the tyres you want to run and it will tell you all the things you need to know plus a diagram of your old wheel set up against your new
Hope this helps
MattTheHat325
Post Thu Sep 22, 2016 2:58 pm
Do you know the offset of your rear wheels bud?
e30-unit-soldier
Post Sat Sep 24, 2016 3:12 am
Et15
MattTheHat325
Post Thu Oct 06, 2016 8:20 pm
You may well have to roll your arches, but 215/40 is the way to go if you are that low on 9's
MattTheHat325
Post Sat Oct 08, 2016 2:38 pm
Presuming they are 16's that is
nazkhan33
Post Sat Oct 15, 2016 8:51 am
I have run stretched tyres on my cab for the past three years with no issues what so ever...
e30-unit-soldier
Post Sun Oct 16, 2016 12:32 am
nazkhan33 wrote:I have run stretched tyres on my cab for the past three years with no issues what so ever...
What's size tyres?
Been told you can go 195/45/16 all round with 9j on the back and 7 1/2 on the front.. Might give that a try
chu346
Post Sun Oct 23, 2016 9:36 pm
195 = :gay:
tcbracing
Post Fri Oct 28, 2016 7:35 pm
I am looking at 225/45/16 on Hartge 16 inch rims and Hartge suspension or 215/50/16; has anyone tried these options?
Topcat
Owner of 1991 E30 Hartge H26 (since 1994)
and 1980 E21 Alpina B6 2.8
e30-unit-soldier
Post Sat Oct 29, 2016 5:05 am
chu346 wrote:195 = :gay:
Sounds good :D
